AirPort/Bluetooth Card
2 Antwoorden 0 Score |
Hoe SSD extern uit te lezen? |
1 Antwoord 1 Score |
MacBook start enkel zonder batterij |
3 Antwoorden 10 Score |
Can I upgrade the memory ram in a Mabook Air Early 2014? |
4 Antwoorden 5 Score |
Adapter to save 12+16 pin ssd |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1466 (EMC 2632 MacBookAir6,2) 1.4 GHz, A1466 (EMC 2632 MacBookAir6,2) 1.7 GHz
Background and Identification
Apple released the updated 13" MacBook Air on April 29, 2014. The model number, A1466, remains the same as previous years, but internally the Air gets Intel's fourth-generation Haswell dual-core processors, and a slight boost in battery life thanks to those chips' increased efficiency.
Technical Specs
Display:
- 13.3-inch (diagonal) high-resolution LED-backlit glossy widescreen display with support for millions of colors
Storage:
- 128GB, 256GB, or 512GB Flash Storage
Processor:
- 1.4 GHz dual-core Intel Core i5 (Turbo Boost up to 2.7 GHz) with 3 MB shared L3 cache or 1.7 GHz dual-core Intel Core i7 (Turbo Boost up to 3.3 GHz) with 4 MB shared L3 cache.
Memory:
- 4G or 8G of 1600MHz LPDDR3L on-board memory
Wireless Connectivity:
- 802.11ac Wi-Fi wireless networking; IEEE 802.11a/b/g/n compatible
- Bluetooth 4.0 wireless technology
Graphics and Video:
- Intel HD Graphics 5000
- Thunderbolt digital video output
- 720p FaceTime HD camera
Ports:
- Two USB 3 ports (up to 5 Gbps)
- Thunderbolt port (up to 10 Gbps)
- MagSafe 2 power port
- SDXC card slot
Dimensions:
- Height: 0.11-0.68 inch (0.3-1.7 cm)
- Width: 12.8 inches (32.5 cm)
- Depth: 8.94 inches (22.7 cm)
- Weight: 2.96 pounds (1.35 kg)2
Additional Links
- Apple's MacBook Air Product Page
