Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Device Will Not Power On
When the power button is pressed, the device will not turn on, and the screen continues to be black.
Low Battery
The device may not be turning on because the battery is dead or almost dead. In order to check if the issue is with the battery, plug in the charger for at least 15 minutes and try to power on the device again. This time, try holding down the power button for at least 5 seconds. If the device still does not turn on, refer to the additional options below.
Faulty Power Outlet
The outlet itself may be the issue and not the battery. Try charging the device using an alternative outlet and following the same procedure explained in low battery.
Faulty Battery
If the device still fails to power on, consider replacing the battery as explained in our battery replacement guide.
Device Will Not Charge
The charger is plugged into the device and connected to the wall, but there is no sign that it is charging, as it will not not turn on and nothing is happening.
Faulty Charger
It is possible that the charger you have is broken or defective. Sometimes, there is no visible damage to the wire even though it doesn’t work. Other times, the wire may be frayed. You may need to replace the charger.
Faulty Outlet
The issue may be that the outlet is not working. Try plugging something else, such as a different charger or even a lamp, into that outlet. If that device doesn’t power on, it may be the outlet that is broken or not currently working. Plug the Jetpack charger into a different outlet.
Faulty Battery
If you have established that your charger and outlet are working, the battery may be what is broken. You may need to replace the battery.
Device Cannot Connect to the Internet
The Hotspot cannot connect to the device.
Low Signal Area
There are certain parts of the U.S. that cannot connect to the Verizon jetpack. This might require you to move to a different location temporarily.
Internal Battery is Low
The battery may be low, which means that it does not have access to any networks. Therefore, connect your charger to the Jetpack.
Data/Storage Used up on Device
Even when the Jetpack is working, it might not connect to WiFi because you have used up all of the data on your phone. Make sure you remove some storage to free up space to use the Jetpack.
SIM Card Not Installed
Make sure your SIM card is properly installed into the device so it can connect to the Verizon network. See this guide to locate the SIM card.
31 opmerkingen
What if the device is turned on and able to receive a signal and connect to a WiFi network but the screen stays black and cannot be turned on?
QC Knights - Antwoord
Jetpack says data usage not available. What does that mean?
Mike Devine - Antwoord
Every time I power up this device, it says “Sim card not detected.” I have to power the device off then power it back on. Totally fixable, but totally annoying. Why is this happening?
Jeffrey Shapiro - Antwoord
The internet JetPack says connected and a Chromebook is being used. When we try to open our email it says, “Verizon Wireless Jet Pack connected; Mobilized data; This site can not be reached.” Do you know why it wouldn’t connect?
Theresa Johnson - Antwoord
I am not sure why it does that but mine does the same thing. Use a VPN. I started using IP Vanish and I never have that problem anymore.
sacha reagan -
