Ga door naar hoofdinhoud
Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement
Wat je nodig hebt
  1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: stap 2, afbeelding 1 van 2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: stap 2, afbeelding 2 van 2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: stap 3, afbeelding 1 van 1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
Conclusie
Analisa Caso
232 Reputatie
2 handleidingen geschreven
Marist, Team S1-G3, Chaterdon Fall 2018 Lid van Marist, Team S1-G3, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 4,540
