Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Computer Will Not Turn On:
The computer does not respond to powering on and shows no signs of life.
Defective Charger
Connect the charger to the laptop and plug the charger into a working outlet. If the Computer is still unresponsive and does not power on you will have to replace the charger. To replace a charger for this computer go to a local store and find a compatible charger.
Malfunctioning Battery
Using a charger known to charge a fully functional laptop connect the charger to a outlet. Remove the battery from the laptop and connect the charger to the laptop. If this allows the laptop to power on with the battery removed this means that the battery is defective and must be replaced. To learn how to replace a battery for this computer, follow this link
Audio Is Distorted:
There are no sounds coming out of the computer or the sound is unclear.
Distorted Audio When Playing a Disc in The Optical Drive
Check to make sure that the disc is secure in the tray. Make sure that you firmly close it and it clicks shut. If this does not solve the problem replace the optical drive by following this guide.
Distorted Playback Through Speakers
First check to see if any enhancements are active. Right click on the speaker icon and select sounds. Then click on the properties tab and select the enhancements tab. Click the box that says “Disable all sound effects”. If this does not solve the problem then replace the speakers.
Display Is Not Showing:
The computer appears to be on but the screen is black and unresponsive.
Device is Turned Off
The computer may not be turned on. If it is not on, click the power button and wait several seconds for the screen to load.
Device is Not Charged
If the power button is clicked but the computer display still does not show, the laptop might need to be plugged in and charged. Plug the computer in to a battery source and wait for it to charge. After several minutes of charging, attempt to power the device on again.
Screen Goes Blank:
The computer is running fine and the screen randomly goes black.
Hard Drive Corruption
Your computer’s hard drive may have become corrupted and broken which caused your operating system to fail. To replace a broken hard drive for this computer, follow this link.
RAM Corruption
If your computer is constantly crashing or freezing, the RAM might be defective. To replace a defective RAM for this computer, follow this link.
Keyboard Is Unresponsive:
The keys will not respond to any commands or are missing.
Keys are Stuck in Place
If individual keys are not responding to commands, they might be stuck in place. To fix this, remove the key by following this link, and then clean out the area underneath the keyboard. After the area is cleaned and removed of any substances, simply snap the key back in place.
Defective Keyboard
If all the keys on the keyboard do not respond to any commands, try replacing the entire keyboard.
2 opmerkingen
My computer shows no signs of life. I replaced the battery charger, but it still won't power up, plus the charging light doesn't come either.
I know that the battery needs replacing, but I read that the HP pavilion G7 1150 doesn't need the battery to run. In fact, they recommend removing the battery if you plan to keep it plugged into a power supply.
Is it possible that the charging port is bad?
And I'd like someone else to verify that this notebook doesn't need a battery to run. It is only required to be plugged into a charger.
Don - Antwoord
Don Hillman - Antwoord
