Ga door naar hoofdinhoud
HP Pavilion g7-1150us RAM Replacement
Wat je nodig hebt
  1. HP Pavilion g7-1150us RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion g7-1150us RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us RAM Replacement, Surface Panel: stap 3, afbeelding 1 van 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us RAM Replacement: stap 4, afbeelding 1 van 2 HP Pavilion g7-1150us RAM Replacement: stap 4, afbeelding 2 van 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us RAM Replacement: stap 5, afbeelding 1 van 1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us RAM Replacement, RAM: stap 6, afbeelding 1 van 1
    • Push outwards on the two clips holding the RAM in place.
  7. HP Pavilion g7-1150us RAM Replacement: stap 7, afbeelding 1 van 2 HP Pavilion g7-1150us RAM Replacement: stap 7, afbeelding 2 van 2
    • Slide the RAM out of its position in the opposite direction of the battery removal switch.
Conclusie
Kyle Dinunno
377 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S6-G3, Peak Spring 2019 Lid van UMass Dartmouth, Team S6-G3, Peak Spring 2019
UMASSD-PEAK-S19S6G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 275
