Ga door naar hoofdinhoud
DYMO® LetraTag®
DYMO® LetraTag® labelprinters zijn ontworpen voor gebruik thuis of op kantoor. Ontdek de handzame LetraTag® 200B, LetraTag® 100H, LetraTag® 100T en LetraTag® 100H Plus
Miesha B
51 Reputatie
0 handleidingen geschreven
2 opmerkingen
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - Antwoord Deel
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 87
Altijd: 896
