Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Acer Iconia One 10 B3-A30 Troubleshooting
This troubleshooting page will help you to identify issues with your Acer Iconia One 10 Tablet
Unresponsive Screen
Device screen fails to respond to touch.
Cracked screen
Sometimes a device’s screen will no longer be responsive if it is too damaged. In this case, the entire screen will have to be replaced.
Pixelated Graphics
If water damage or physical damage occurs, it can affect the touch screen digitizer. This in turn will create pixelated graphics and the screen will no longer be responsive. In this case, you would have to replace the screen.
Poor/No Wifi Connectivity
Connectivity to WiFi is very poor or nonexistent
WiFi is not enabled or connected to the router
Make sure the wifi capabilities are enabled by going to settings, and ensuring that the Wifi option is set to “on”. After this step, check if your device is connected to your router and if not, do so now.
Distance from the router is too great
If the tablet is too far from the router, the signal will be weak and if this is the case, move the device closer to check if the connectivity improves. If it does not, then move on to the next step below.
WiFi chip/antenna is faulty
If none of the above help address the problem, then the device will need it’s WiFi chip/antenna replaced, which means replacing the motherboard here.
Device Won't Power On
When pressing the power button the tablet does not respond.
Charger doesn’t work properly
If the device isn’t charging, this could actually be a charger problem and not the device. Make sure the charger you have chosen works and test it on other devices first in order to ensure it’s working properly. If the device will work while plugged in but turns off once unplugged the battery is faulty and needs to be replaced.
System is frozen
With this device there is a known problem of it freezing when powered off. To see if this is the problem attempt to boot it into bios by holding the volume up and power button for 40 seconds. If the screen turns on simply exit the bios and windows will boot up.
Power button is dislodged/broken
Once it is confirmed that the device is charged, hold down the power button for 3 seconds. If nothing happens the power switch may be faulty and needs to be replaced.
Motherboard is faulty
If none of the above have resolved the issue, then your best bet will be replacing the motherboard completely which will be shown here.
Tablet Frequently Overheats
The device becomes unusually hot and then shuts down.
Battery is faulty
Over time batteries can become defective after heavy use or trauma. If the overheating occurs after using the tablet for long periods time consider replacing the battery. To find out how click here.
If neither of the above posted solutions helped consider replacing the motherboard. If the motherboard is malfunctioning it can cause overheating issues by not properly distributing power. For a guide how to replace it click here.
Camera Problems
Camera is flipped using certain apps or, is completely unresponsive.
Flipped camera
If the camera is flipped using applications which specifically use the camera (Ex: Instagram, Snapchat). Try deleting and reinstalling the application, and try using the camera again.
Unresponsive Camera
- Factory Reset.
- Turn the device off.
- Press and hold the Volume up button, and then press and hold the Power button.
- Release the Power button after 3 seconds.
- Release the Volume up button once the device powers on.
- Use the Volume up and down to navigate through the Android recovery menu.
- In the menu, select “Wipe Data/ Factory Reset”.
- Confirm the Factory Reset.
Once the device powers on, follow the instructions on your screen to set up your Tablet.
- Using the App Store to download a new camera app.
If you are still facing issues after resetting the device, you should try downloading another camera application on the Google Play Store.
If nothing works,
You should try contacting Acer service support to get help on your device
Or, you should take a look at the replacement guide for the Camera here.
8 opmerkingen
IT turns on, but only the screen whit acer Explore beyond limmits i stansing on the screen and nothing happens :(
Tom Rune nilsen - Antwoord
It will let me sign on, but then the acer logo comes up and it just sticks there. Is there anything I can do.
Sue Marley - Antwoord
Will not turn on. Only to recovery screen. Then selecting any of those options does not help.
biidaankwad king - Antwoord
my laptop wont link with my acer ivonia tablet , i have used 6 usb leads and nothing , can you solve this for me please
silverdave01 - Antwoord
faulty keyboard
barry.morse2 - Antwoord
