Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Sonos Play 5 te repareren, gebruik onze reparatiehandleidingen.
  1. Sonos Play 5 Teardown, Sonos Play 5 Teardown: stap 1, afbeelding 1 van 1
    • Pull the front bezel forward to remove. It's only secured by velcro
  2. Sonos Play 5 Teardown: stap 2, afbeelding 1 van 3 Sonos Play 5 Teardown: stap 2, afbeelding 2 van 3 Sonos Play 5 Teardown: stap 2, afbeelding 3 van 3
    • Gently peel the rubber base away from the edges to remove 6 phillips head screw.
    • The base plate will lift straight up to reveal 3 metal stanchions. I believe these are the wireless antennas.
  3. Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: stap 3, afbeelding 1 van 1
    • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
    • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
    • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Tim U
101 Reputatie
1 Handleiding geschreven
1Gids Commentaar
This teardown is stale! Please continue. :) Thanks.
William Small - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 100
Altijd: 15,909
