Inleiding
The Teardown is pretty much the same as other Samsung Slider phones
Deze demontage is geen reparatiehandleiding. Om je Samsung Intensity te repareren, gebruik onze reparatiehandleidingen.
Remove the 8 screw that hold the back cover down.
Carefully pry back piece off
Start at the bottom and work toward the top.
Carefully remove the main board
Make sure to not tear the microphone cable, pry it from the phone carefully
Remove the 4 screw the holds the slider to the phone assembly
one of the screws will be behind the hinge
Carefully pry slider assembly loose from display assembly
LCD comes out pretty easily
Pry it from the bottom and work up the sides to release it if stuck
The glass can be removed with a little heat from a heat gun or blow dryer
Pry it out from the outside edges working around carefully
Deze handleiding insluiten
Kies een formaat en kopieer de onderstaande code om deze handleiding in te sluiten als een kleine widget op uw site / forum.
Voorbeeld
