Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Tweezers te repareren, gebruik onze reparatiehandleidingen.
  1. Reversed tweezers Teardown, Reversed tweezers Teardown: stap 1, afbeelding 1 van 3 Reversed tweezers Teardown, Reversed tweezers Teardown: stap 1, afbeelding 2 van 3 Reversed tweezers Teardown, Reversed tweezers Teardown: stap 1, afbeelding 3 van 3
    • This my friends, is the first ever iFixit-made-tool teardown on iFixit
    • Stainless steel body and nylon tips, with the iFixit logo printed on it...
    • Reversed so you can hold tiny Lego hats even when your hands are busy...
  2. Reversed tweezers Teardown: stap 2, afbeelding 1 van 3 Reversed tweezers Teardown: stap 2, afbeelding 2 van 3 Reversed tweezers Teardown: stap 2, afbeelding 3 van 3
    • Time to tear it down!
    • Its not often that regular Philips screws are used on modern devices!
    • So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Have dreams come true?
    • We Remove the Last parts anddddd...
  3. Reversed tweezers Teardown, Final Thoughts: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Nylon Tipped Tweezers
    $2.99
    Koop
    What is the pitch between the screw holes?
    Colton - Antwoord
    Also, do you know what the thickness of the tips are and the length of the screws?
    Colton - Antwoord
Aiden
17.429 Reputatie
21 handleidingen geschreven
8 opmerkingen
Where can you find the replacement parts?
echow2001 - Antwoord
Repairability: 11 out of 10.
Jake Rose - Antwoord
lol i actually needed this to fix mine
Luke - Antwoord
Very glad to know replacement tips are sold! I had no idea these were nylon until I melted the ends. Whoops!
The Purple Ender Eye - Antwoord
If you have the order number of the original or a photo of the kit it came with, theyll replace it for free if you use their email support.
Tito_deTrapio94 -
So I have to purchase the Nylon Tipped Tweezers to get a set of Nylon Tips to replace my Reverse Tweezers Nylon Tips? Can't jus buy the tips?
Randy
Clarence Hayes - Antwoord
You can definitely get the tips only. And they are covered by the lifetime warranty. Just contact their email support. they sent me 2 replacement packs for free.
Tito_deTrapio94 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 3,502
