Tools Featured in this Teardown
Introduction
This is a teardown of the RIM Blackberry.
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
To remove the phone's internals, start by loosening one side by pulling gently.
Locate a hook on the right side of the internals below the volume wheel.
Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
On the front side of the internals, locate the the three screws that are highlighted in red.
Carefully remove screws from the internals, using a T6 torx screwdriver
