Inleiding
We've been accused of favoring one fruit over all the rest. Some have even claimed that we love one juicy snack more than others.
No more. To show some appreciation towards other members of the fruit family, we decided to test out the accessibility, repairability, and end-of-life design of the Orange.
Tried the teardown at home with mild to moderate success? Celebrate with an Orange Teardown t-shirt! Or if you're having technical difficulties with your Orange, make sure you've identified your Orange correctly, and then visit our Orange Troubleshooting Guide to figure out what's going on. Perhaps you just need the right tool for the job.
Want to know more about how we juiced this Orange? Read the full behind-the-scenes account on the iFixit blog.
Check out all the latest fruits of our labor by following iFixit on Twitter or "Liking" us on Facebook.
Wat je nodig hebt
The Orange. Nature's mysterious orange sphere. Believed to be the hybrid between a pomelo and a mandarin, the Orange is a staple food that has been cultivated since ancient times.
So what components make up this juicy device? Here are the tech specs:
Orange peel
Orange seeds
Orange pith
Orange pulp
Orange juice
Orange color (corresponding to a 620 nm wavelength)
Before we could start penetrating the thick outer peel protecting the Orange's sweet innards, this small mechanoid appeared out of thin air. Cue Final Fantasy battle theme.
After a protracted tussle, the Orange emerged victorious. The fate of the mechanoid is unknown—it vanished mysteriously into the arcane shadows from whence it came.
Strike a pose; Juxtapose. We set up our customary comparison shot to contrast the Orange to an Apple.
Gereedschap gebruikt in deze stap:Heat Gun$24.99
What exactly adheres the outer layer to the Orange? We aren't really sure. We're familiar with how much adhesive devices these days employ and are prepared to act accordingly.
In any case, the only sure-fire way to know is to heat the Orange up with our heat gun. This has never been done in the history of Orange disassembly. This truly is one small step for an Orange, one giant leap for fruitkind.
Orange, the manufacturer.
Most likely apple
At this point, we are fairly confident that the heat gun sufficiently loosened any adhesive in the Orange. Time to get to the tearing down!
To our surprise, our normal approach does not seem to apply to this strange device.
You have the wrong style of guitar pick. You need the one that comes with most apple tool kits (but have no purpose on an apple) that is much thicker and has three edges that are thinner. These edges will act in a similar fashion as the oOpener tool.
Thanks for the detailed teardown. Is there any possibility or reassembly with the different orange models?
P.S. Yes, I realize it is now the 3rd of April. :)
Gereedschap gebruikt in deze stap:iFixit Opening Picks (Set of 6)$4.99
Oddly, we have no luck with a guitar pick, plastic opening tool, tech knife, ruler, pair of tweezers, or even an iSesamo!
Having no luck with our vast array of poking, prodding, and prying tools, we figure a little more heat might be necessary.
Gereedschap gebruikt in deze stap:P2 Pentalobe Screwdriver iPhone$5.99
With no other option in sight, we turn to our last resort for impossible-to-open devices: the Pentalobe screwdriver.
Phooey! That didn't seem to work, either. We are running out of ideas…
Gereedschap gebruikt in deze stap:iOpener$19.99
Just when we think all hope is lost, a tool descends upon us from the repair heavens as Morgan Freeman's voice booms throughout our teardown room.
Behold! The oOpener!
A tool rumored to open any orange in the universe, we had only heard about the oOpener in old repair myths shared around company campfires.
While most disassembly tools, such as the iOpener, can be fabricated, the oOpener is said to only be available to those who are pure of heart, mind, and vision of a repair-friendly world.
We quickly get to work slicing through the Orange's thick peel with the oOpener, spiraling down like whirlybirds in the breeze.
Having the right tool for the job is a truly heartwarming experience. We hold back the overflow of nostalgia as the oOpener brings back fond memories of early spudger escapades.
A plastic opening tool allows us to finish the job started with the armor-piercing strength of the oOpener.
Prying things open with a plastic opening tool—finally a familiar tune for us.
Now that we've removed the rind, let's take a brief scientific look at the make-up of the Orange in the first ever segment of Fruit Science with iFixit!
Oranges and other citrus fruits are of the order Hesperidium—a kind of berry with a tough, leathery rind.
The three important layers of such fruits are the exocarp (rind), mesocarp (pith), and endocarp (the delicious edible part).
One final obstacle stands between us and sectioning the Orange into its component wedges.
Gentle prying with a plastic opening tool separates the navel, freeing up the top of the Orange for separation.
This appears to be yet another irreversible step; the Orange's repairability score will likely take another hit.
We love modular devices, and this one is as modular as they come. Having modular components makes replacing each component a lot
tastiereasier. -
All ten major internal components of this device are easily removable. However, we are worried that they might not go back together as easily as they come apart, a common problem in fruit repair.
Though the Orange's repairability is highly questionable, we do admire its end-of-life design. It is completely recyclable, compostable, and delicious-able. We hope that devices like this will some day catch the attention of other device manufacturers and help keep electronics out of landfills…unless they are compostable, of course!
Gereedschap gebruikt in deze stap:Precision Utility Knife$4.99
It's time to unlock the deeper mysteries of the Orange.
Unlike some of our more complicated teardowns, a steady hand and a sharp blade are the only tools we need to get a view of a section's internal structure.
With the wedge split, we get a serious look at the Orange's seriously small seeds.
These extremely small components seem to be nested deep within the device. Repairability will definitely take a hit for this one.
Navel Oranges, such as this, have small, sterile seeds that cannot be used to reproduce more Oranges—a cutting from an existing fruit-bearing tree must be grafted to another tree.
We assume the device is supported by Orange Mobile but it remains to be seen if it will be released to other carriers in the future.
Orange Repairability Score: O out of 10 (10 is easiest to repair).
Normal operation requires breaking the outer case.
Partition membranes and linings are exceedingly fragile, and will break during casual use.
Impossible to reassemble after opening.
All components secured with some sort of natural adhesive.
Internal components filled with acid.
It was so funny!
Please can we have an oyster disassembly guide? I’ve got an iSlack but the shell is too rough for it (or any other suction cups) to grip. Plastic opening tools don’t seem strong enough, and whilst the jimmy might do the job, is this really the correct tool to use?
I have shucked an oyster with the Jimmy before. I was successful, but then that Jimmy became my dedicated oyster-shucking jimmy.
18 opmerkingen
The Banana teardown is one of our favorites.
@stcyr1up WHAT DO YOU MEAN “April fools day“ really useing this irl
That is absolutely hilarious! I'm glad you guys don't take yourselves so seriously. I think I'll hold off on orange adoption until 2.0. Maybe by then they'll have done something about that zero repair-ability...
Have you tried making an orange into a secret note carrier? Pry the stem nub off the one end of the whole orange. Take a pencil/pen/awl type point tool and pop through to the pace down the center of the orange sections. Now take a smallish note with a message and roll it into a small tube and insert in the space. Glue the stem nub back on the orange over the insertion hole. The person who peels the orange will have a pleasant surprise.
To reassemble, follow steps in reverse order.
It’s a good thing the device is not to be reassembled. Makes it easier to spot if a refurbished item is sold as a new one. The life time of the device certainly could be better, but it’s great that there’s a very easily available and virtually cost-free infrastructure to recycle the device’s components. Would be nice to see teardowns on some other unsual tech you stumble about!
On top of voiding my warranty, I dropped it, and now I can't get it repaired! I'm going to have to get a replacement orange! Lol
Raspberry teardown when?
It has been too long ... You need to do another of these mysterious "Fruit" things...
May I suggest a Raspberry? Although you may end up with a sticky microscope.
Or... you could try a Durian (Seriously Evil Grin)
everseeker - Antwoord
