Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Nintendo 64 te repareren, gebruik onze reparatiehandleidingen.
  1. Nintendo 64 Teardown, Nintendo 64 Overview: stap 1, afbeelding 1 van 1
    • The Nintendo 64 was Nintendo's third home console. Released in 1996 for the US and Japan, the N64 boasted 64-bit graphics for the most realistic gaming experience ever made to date. The N64 was co-developed by Nintendo and Silicon Graphics.
    • NEC VR4300 64-bit CPU, running at 93.75 Mhz
    • Silicon Graphics Reality Coprocessor (RCP) GPU
    • 576i (720×576) Composite output
    • Support for up to 4 players
  2. Nintendo 64 Teardown: stap 2, afbeelding 1 van 3 Nintendo 64 Teardown: stap 2, afbeelding 2 van 3 Nintendo 64 Teardown: stap 2, afbeelding 3 van 3
    • Let's take a look at the I/O, shall we?
    • 4 N64 controller ports
    • Nintendo 64 Game Pak slot
    • Composite video cable port
    • N64 power supply port (12V/3.3V DC switching)
  3. Nintendo 64 Teardown: stap 3, afbeelding 1 van 3 Nintendo 64 Teardown: stap 3, afbeelding 2 van 3 Nintendo 64 Teardown: stap 3, afbeelding 3 van 3
    • Let's begin by removing the top cover.
    • Remove the 6 Gamebit 4.5mm screws found at the 4 corners and near the top-middle and bottom-middle.
    • Using a metal spudger, take out the Jumper Pak from its slot and set it aside.
    Protip: If you do not have a spudger handy, the corner of the door for the Expansion Pak slot will do the trick.
    satidragon - Antwoord
  4. Nintendo 64 Teardown: stap 4, afbeelding 1 van 3 Nintendo 64 Teardown: stap 4, afbeelding 2 van 3 Nintendo 64 Teardown: stap 4, afbeelding 3 van 3
    • Flip the console upright, and the top cover just comes right off.
    • Remove the 10 crossbar screws using a Philips #2 screwdriver.
    • Take out the 2 screws holding in one piece of the expansion slot shield, also with a Philips #2
    • The 2 black screws and the one at the bottom left of the expansion slot shield are easily removed with a Philips #2.
    • Finally, remove the 2 long screws from the 2 ends of the slot with a Philips #0.
  5. Nintendo 64 Teardown: stap 5, afbeelding 1 van 3 Nintendo 64 Teardown: stap 5, afbeelding 2 van 3 Nintendo 64 Teardown: stap 5, afbeelding 3 van 3
    • Remove the 3 pieces of the expansion slot shield.
    • Make sure to remove these pieces BEFORE removing the heatsink crossbar.
  6. Nintendo 64 Teardown: stap 6, afbeelding 1 van 3 Nintendo 64 Teardown: stap 6, afbeelding 2 van 3 Nintendo 64 Teardown: stap 6, afbeelding 3 van 3
    • The heatsink crossbar comes right off, which gives us access to the motherboard shield.
    • The 5 screws on the two sides of the shield are swiftly removed with a Philips #2
    • The 2 screws on each side of the Game Pak slot are quite long, and are removed with a Philips #2.
    • With that, the shield slips right off, letting us gaze at the Nintendo 64's source of power.
  7. Nintendo 64 Teardown: stap 7, afbeelding 1 van 2 Nintendo 64 Teardown: stap 7, afbeelding 2 van 2
    • On the motherboard are 3 very pronounced steel blocks, which indicates that the important stuff is under there. But before removing these, it's best to take the motherboard out of the bottom case.
    • In order to remove the motherboard, unscrew the 4 Philips #2 screws from the two back I/O ports, allowing extraction of the motherboard.
  8. Nintendo 64 Teardown: stap 8, afbeelding 1 van 2 Nintendo 64 Teardown: stap 8, afbeelding 2 van 2
    • Using a Jimmy, pry off each chip's heatsink, revealing the console's processing units.
    • Nintendo CPU-NUS-A
    • Nintendo RCP-NUS
    • Nintendo RDRAM18-NUS-B (2x2MB modules)
    Did some research, apparently you don't want to pry off the heatsinks if you plan to put the unit back together and don't have thermal pad replacements (the rubbery squares between the chips and the heatsinks that's holding it together), otherwise some small gaps will form between the chips and the heatsinks when reassembling, which is obviously bad for cooling.
    Arty Boomshaka - Antwoord
    Can standard Arctic Silver thermal paste work?
    you will want actual thermal pads instead of thermal paste, since the thickness is needed for the heatsinks to reach the main heat spreader (with the 10 screws from step 4), otherwise overheat conditions exist.
    Andrej Walilko - Antwoord
    I just wanted to know what thermal pad thickness I need because for some reason I can find the sizes for the GameCube and wii but nothing on N64.
    Allan Johnson - Antwoord
  9. Nintendo 64 Teardown: stap 9, afbeelding 1 van 1
    • And thus concludes a successful teardown of one of the greatest consoles of all time.
Christian Marmolejos
351 Reputatie
1 Handleiding geschreven
4 opmerkingen
Thank you, this tear down was real helpful. I was able to open up an N64 and clean the corrosion between some pins that kept it from turning on. :D
Nocturnal 007 - Antwoord
I’m really glad to hear that! The N64 has always had a special place in my heart since it was the first home console I ever had.
Christian Marmolejos -
dang one in the same Christian same first console my second was the PlayStation 1(actually just called PlayStation) and the PlayStation 2 my third the Nintendo GameCube then handheld consoles the game boy, game boy advanced, and Nintendo 2dsi , and the Nintendo 3-DS, and then fourth the non-handheld online consoles the Wii and the Xbox 360.
nathanrust123 - Antwoord
This in my opinion was one of the best consoles. The Zelda games for the 64 were amazing. Love the idea I can fix mine.
Joshua Graham - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 34
Afgelopen 7 dagen: 184
Afgelopen 30 dagen: 784
Altijd: 44,603
