The Giiker Super Slide is a game console based on the game klotski. Opening it up is fairly easy, if you manage to get the adhesive sticker off first try. If you fail, this quickly becomes a time consuming endeavor. There are no available spare parts for the console and all modules are soldered to the main board. That being said, it only uses one screw type and one can easily replace the two AA batteries.
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Giiker Super Slide te repareren, gebruik onze reparatiehandleidingen.
Remove the adhesive sticker (large) carefully from the back
The sticker uses very strong adhesive. If you fail to get this off in one try, you will need isopropyl alchohol and an ifixit opening tool to scrape off the parts of the sticker penetrated by the alchohol
Beware the two small wires connected to the back for the speakers
Note that the inside magnets are not secured down, be very careful to not move the piece bay when removing the back unless you want to spend a lot of time putting them back in
The top left corner of the back has some very light clips. Carefully twist side to side to get this open
To get the proper orientation of the magnets when reinserting, take a play piece and put the magnets on the piece back so they orient themselves. Using this orientation, insert them into the chassis and test with the back on that all are oriented correctly by putting the piece in play area. If they are not oriented right, the piece will not align
