Here we see the device. It is predominately cheap plastic and thin stamped metal.
It looks and feels very light and cheap, not a good sign. Though as they say don't judge a book by its cover.
Lets look at the other side. Holy Long Leads Bat Man! Those leads (in the red box) are WAY too long. Compare their length to the ones on the USB connector (in blue). While the soldering looks OK, the long leads show a general lack of attention to detail and cutting of costs.
Now we get a good look at the circuit board in general. The more signs of cost cutting. The solder mask (the stuff that makes the PCB green) has huge empty spaces around the solder pads. You can clearly see the brown PCB through there. This increases the risks of short circuits etc. Once again cheap design.
The main IC seems to be an MC34063 switching regulator. A veritable workhorse in USB chargers. While this IC can drive up to 1.5A it is only considered good for up to 700mA continuous before heat becomes an issue. Uh oh.
Here we see the stock schematic from the database.
In the next image we see the schematic used in the device. We see many values have changed.
The biggest change is that Rsc is 0.22ohms. This gives an Ipk of 1.36A, which gives an Iout Max of 0.68A. This is FAR from the quoted 1A.
Also, the input and output capacitors have been reduced in size to 10uF and 100uF respectively. This means that we will see MUCH larger ripple on the output. Possibly falling out of USB spec and putting the attached device at risk.
Quite simply, the device is a rebadged 500mA or 750mA USB charger at best. It is NOT 1A capable, despite what the sticker on the body says.
10 Opmerkingen
I tore down the same device with much the same comments - http://mm0hai.net/blog/2012/08/01/Messag...
Could you do a tear down of the more advanced usb car chargers, it would be interesting on how these are made and work
The right conclusion of R(3.6K) it has to be connected to the right conclusion of L (220uH).
I have already ordered a charger from the best seller of Amazon
