Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Amazon Tap te repareren, gebruik onze reparatiehandleidingen.
  1. Amazon Tap Teardown, Amazon Tap Teardown: stap 1, afbeelding 1 van 3 Amazon Tap Teardown, Amazon Tap Teardown: stap 1, afbeelding 2 van 3 Amazon Tap Teardown, Amazon Tap Teardown: stap 1, afbeelding 3 van 3
    • This is Amazon's first portable, Alexa-powered device, so we're excited to see how they've switched things up. Features include:
    • Button-activated Alexa Voice Service
    • Up to 9 hours of audio playback on a single charge
    • Dual 1.5-inch drivers and dual passive radiators for bass extension
    • Single-band 802.11b/g/n Wi-Fi and Bluetooth 4.2
    • Charging cradle
    • While we're sharpening our tools, here's a sneak peek via X-ray.
  2. Amazon Tap Teardown: stap 2, afbeelding 1 van 3 Amazon Tap Teardown: stap 2, afbeelding 2 van 3 Amazon Tap Teardown: stap 2, afbeelding 3 van 3
    • Faceoff! On the right we have the Tap, and on the left, its wirebound siblings. Go on, guys, introduce yourselves.
    • Tap's charging cradle sports two spring contacts that connect to the base at any angle, thanks to this target-shaped pair of circular contacts on the bottom of the Tap.
    • Taking a closer look, we see Tap's model number, PW3840KL, alongside all the usual suspects.
  3. Amazon Tap Teardown: stap 3, afbeelding 1 van 3 Amazon Tap Teardown: stap 3, afbeelding 2 van 3 Amazon Tap Teardown: stap 3, afbeelding 3 van 3
    • With a couple other cylindrical Amazon teardowns under our belt, we know the drill. The first piece out of this puzzle is the base's rubber footing.
    • Seconds later, a few T9 Torx screws bite the dust, and we get our first look inside.
    • It's just a peek, though—our path forward is blocked by the molded plastic housing. Time to check for other possible points of entry.
  4. Amazon Tap Teardown: stap 4, afbeelding 1 van 3 Amazon Tap Teardown: stap 4, afbeelding 2 van 3 Amazon Tap Teardown: stap 4, afbeelding 3 van 3
    • Undeterred, we turn our attention spudger to the rubberized control panel at the other end.
    • With some assertive prying, the plastic clips give way to reveal a control button breakout board featuring some buttons, a microphone, and a lone IC:
    • National Semiconductor LP55231 Programmable 9-Output LED Driver (as seen in the Echo and Echo Dot)
    • Unfortunately, there are no fasteners lurking at this end either. Time to get creative destructive!
    Is there only one microphone module?
    jake - Antwoord
    Easier to pry from front (mic side) than back like pic shows.
    Be careful with ribbon cable. Tug on it, and it’ll come right out of the inside…and you can’t reconnect without finishing disassembly.
    anonymous 7859 - Antwoord
  5. Amazon Tap Teardown: stap 5, afbeelding 1 van 3 Amazon Tap Teardown: stap 5, afbeelding 2 van 3 Amazon Tap Teardown: stap 5, afbeelding 3 van 3
    • Thwarted by a lack of screws at either end, it seems that there's no easy way to Alexa's heart. So, let's do things the hard way.
    • First off of the Tap's cowling is the stretchy fabric wrap, which we unroll from the cowling's firmly adhered outer surface.
    • Aaaaand still no screws.
    • What we have here is a sticky situation. Many a brave pry tool met its doom attempting to bypass the Tap's flypaper exterior.
    No need to do this. Just unroll from around the bottom to allow inner assembly to slide out.
    Pry out out talk and power/bluetooth/aux/usb button covers before going to next step. It’ll makes it WAY easier to slide the inner assembly out of the outer casing. Pry towards sides—and not near top or bottom.
    Thank you all and “anonymous 7859” you are right! Removing the power/bluetooth/aux/usb button covers can save you (the job on/and ) the external Fabric. Then, without the button covers and using two Flat screw drivers, just below the headphone, I pull enough the external layer up creating a tunnel for the headphone connector just to slide-out!
    Edson CodeInitiatives - Antwoord
  6. Amazon Tap Teardown: stap 6, afbeelding 1 van 3 Amazon Tap Teardown: stap 6, afbeelding 2 van 3 Amazon Tap Teardown: stap 6, afbeelding 3 van 3
    • After a good amount of finagling, we finally manage to wriggle the cowling free by sliding it over the power, Bluetooth, and microphone buttons.
    • It may not look like progress, but it is. Just a few screws stand between us and those Taptastic interior goodies.
    • Suddenly the microphone button comes out all willing-like. That would have been helpful in the prior step, but we'll take it!
    Prying out talk and power/bluetooth/aux/usb button covers makes it WAY easier to slide the inner assembly out of the outer casing. Pry towards sides—and not near top or bottom.
    yes.. taking the microphone button off first made it so much easier.. awesome!
    Andy - Antwoord
  7. Amazon Tap Teardown: stap 7, afbeelding 1 van 3 Amazon Tap Teardown: stap 7, afbeelding 2 van 3 Amazon Tap Teardown: stap 7, afbeelding 3 van 3
    • With the sheath shucked and a handful of screws dispatched, the Tap falls open like a book.
    • And things are looking up! The I/O panel, mounted by way of a couple screws, attaches to the motherboard via a flex cable and slides right out.
    • That means replacing the USB port, a commonly failing component in mobile devices, will be possible if not totally painless.
    • Moving right along, the motherboard jumps out to join the party.
    The motherboard is secured to the speaker seated under it via adhesive. Pull firmly but gently to separate!
    Rick - Antwoord
    It’s pretty obvious, but remove the rubber retaining ring from bottom before you try to separate.
    ach.. the “handful of screws” are security torx screws that are deeper than I can reach with my small stubbies.. I need the TR9 Torx Security Screwdriver above I guess..
    Andy - Antwoord
  8. Amazon Tap Teardown: stap 8, afbeelding 1 van 2 Amazon Tap Teardown: stap 8, afbeelding 2 van 2
    • Reaching the brains of this smart speaker, we do our due diligence and identify all the key players:
    • Freescale/NXP MCIMX6L8DVN10AB i.MX 6SoloLite Applications Processor
    • Samsung KMNJ2000ZM-B207 512 Mb DDR2 SDRAM Memory (likely)
    • Maxim MAX77697 PMIC
    • Coilcraft SER1360-272L High Current Shielded Power Inductor
    • Texas Instrument TPA3130 15W Filter-Free Class D Stereo Amplifier
    • Broadcom BCM4343 Wi-Fi and Bluetooth 4.2/Bluetooth Smart SoC
    • Maxim MAX98090 Ultra-Low Power Stereo Audio Codec
    The KMNJ2000ZM_B207 is a 4-gigabit LPDDR2 RAM chip. That means this speaker is sporting 512 megs of RAM. Not bad at all for a speaker.
    Brion Davis - Antwoord
    The same chip also provides 4 gigabytes of flash storage as well.
    The MCIMX6L8DVN10AB processor houses an ARM Cortex-A9 core. I am quite shocked as the Tap is actually better endowed with both RAM and processor than the more expensive Echo.
  9. Amazon Tap Teardown: stap 9, afbeelding 1 van 2 Amazon Tap Teardown: stap 9, afbeelding 2 van 2
    • Next to come out is a standard 18650 Lithium Ion cell, widely used in the industry from Tesla vehicles to self-balancing boards.
    • This unit is rated for 2850 mAh at 3.7 V to yield 10.54 Wh, which Amazon says will provide up to 9 hours of music playback.
    • Compare that with the 3.8 V, 2750 mAh, 10.45 Wh battery in the iPhone 6s Plus—a battery with a similar output for a radically different job.
    can you please, peel off the blue shrink sleeve to see the original cell inside
    kun4oto - Antwoord
  10. Amazon Tap Teardown: stap 10, afbeelding 1 van 3 Amazon Tap Teardown: stap 10, afbeelding 2 van 3 Amazon Tap Teardown: stap 10, afbeelding 3 van 3
    • We're down to the real heavy hitters: the speakers!
    • These little 1.5-inch drivers each pair with a larger passive radiator to improve lower end frequency response without additional large drivers or a base response tube.
  11. Amazon Tap Teardown: stap 11, afbeelding 1 van 2 Amazon Tap Teardown: stap 11, afbeelding 2 van 2
    • Okay but seriously, those passive radiators aren't even connected to anything. How important could they be?
    • We thought you'd never ask. What we have here is a reassembled Tap with a conspicuous absence of passive radiators. So how does it sound?
    • In a word, bad. Just for kicks, we ran a quick audio spectrum test with the passives out, and again with them in. Our puny human test subjects couldn't even hear the signal below 120 Hz—until we reinstalled the passive radiators, at which point they confidently identified a bassy rumble all the way down at ~90 Hz.
    • Good job, passive radiators.
  12. Amazon Tap Teardown: stap 12, afbeelding 1 van 2 Amazon Tap Teardown: stap 12, afbeelding 2 van 2
    • Amazon Tap Repairability Score: 7 out of 10 (10 being the easiest to repair)
    • The battery, control board, I/O board, and speakers all connect to the motherboard via standard cable connectors.
    • Most components are held in with easily-undone clips or standard screws.
    • Removing the cowling requires a significant amount of force, but it is a nondestructive process.
    • Repairs are straightforward if you know your way in, but could be daunting without a service manual.
    • Tough adhesive holds the rubber footing to the base.
Evan Noronha
223.469 Reputatie
168 handleidingen geschreven
16 opmerkingen
I have been waiting for this teardown of the Amazon Tap. Thank you!
Richard Wade - Antwoord
I can't tell from the picture but do you think a better wifi antenna could be added?
Michael Smith - Antwoord
How many microphones does it have?
Only 1?
Peter Cooney - Antwoord
Can the outer speaker cloth be reattached? Why no red dot for that?
Bryce Nesbitt - Antwoord
How easy would it be to hack in an audio stereo output jack? (to connect to an external stereo or boom box.)
mmmmmmm - Antwoord
Connect 4 pole headphone jack to pins 4, 5, 6 and 7 on the MAX98090 audio codec. Look up the datasheet for the chip for exact specs. It has it's own headphone amp built in.
Where can I find the data sheet for the chip MAX98090 to connect a headphone jack to the unit?
Bob ohler - Antwoord
does anyone know how i can flash the firmware to factory settings? I have one that was used as a store display model and the wifi/bluetooth are disabled and it has a recorded sales message on it. thanks in advance.
arran biggart - Antwoord
Thanks for this info. I had a busted speaker in my Tap and this helped me to save money by just buying the speakers and not having to replace the whole thing. Also I was able to get then cowling off without taking the cloth off all the way but that was only because of this tutorial. Once again thank you.
Marc Allen - Antwoord
My first time to find this sight but….. II FFREAKING LOVE IT!
MY NEW FAVORITE!
AWESOME JOB!
willyguyver - Antwoord
Thanks! Couple of improvement…
Step 4: Easier to pry at the front (under mic) than the back where your pic shows. Careful! Ribbon cable comes right out…and you can’t reconnect until you’re fully inside.
Step 5: No need to completely remove fabric. Just unroll from around the bottom to allow inner assembly to slide out.
Step 5 1/2: Prying out talk and power/bluetooth/aux/usb button covers makes it WAY easier to slide the inner assembly out of the outer casing. Pry towards sides—and not near top or bottom.
Step 6: With the buttons removed, inner assembly slides out BOTTOM pretty easy—except that it catches on the aux jack. Had to to carefully pry outer case around it.
Step 7: Remove rubber retaining ring from bottom.
In my case, the unit had stopped making any sound after it was dropped—but otherwise functioned normally. Upon inspection, coil had come loose from motherboard. A little solder and glue…and voila! It works great again.
Went back together pretty easy. Again, careful with top ribbon cable!
Hi! Thanks for your comments—however, as stated in the banner at the top, this is not a guide and should not be used as instructions. Glad things worked out for you!
Jeff Suovanen -
Thanks a ton!! Your instructions really helped guide me inside the tap!
I think, iFixit should change the step where they remove all of the fabric, to one from your step.
Also, regarding working around the AUX jack, while sliding the cowling over the core, I covered the jack with a thin metal spudger and then holding it in place, pushed the cowling over it. This way re-installation was also easier.
My tap’s battery backup had reduced a lot! Changed the battery and everything is fine now!!
Sji -
So is it worth pulling it apart if I am stuck with it not working? Constant blue light in front. Won't respond to pushing buttons to reset. I love my tap and so sad it is dead.
ethelser5 - Antwoord
Can anyone tell me the type of speaker this is and the serial number and the type of battery?Thanks
firedawg59 - Antwoord
My  Alexa has no sound she is responding but I cant hear  anything the volume is turned up. What can be the problem?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 65
Altijd: 29,783
