Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je Amazon Luna Controller te repareren, gebruik onze reparatiehandleidingen.
  1. Amazon Luna Controller Teardown, Remove the Front Plate: stap 1, afbeelding 1 van 3 Amazon Luna Controller Teardown, Remove the Front Plate: stap 1, afbeelding 2 van 3 Amazon Luna Controller Teardown, Remove the Front Plate: stap 1, afbeelding 3 van 3
    • There are no visible screws anywhere on the outer shell of the Amazon Luna controller. Screw posts will be revealed after removing the front plate surrounding the face buttons and analog sticks.
    • The top plate is held down by several clips around the edge of the top plate. This plate needs to be removed by prying along the edge and separating the plate from the mid-frame.
    • With a flat spudger or a flat-head screwdriver, start at the bottom corner of the controller between the headphone jack and the handle, and carefully pry off the corner of the plate.
    • Once you have the plate starting to separate, take a coin pick, insert into a gap of the crease between the top and the handle, and carefully slide up and along the top of the handle, tilting the pick to pry off each clip.
    • Repeat this process, unbinding each clip around the top plate starting from the bottom near the handles up to the top of the Luna button in the top-middle of the controller. The plate will lift off when all the clips are undone.
  2. Amazon Luna Controller Teardown, Remove the screws: stap 2, afbeelding 1 van 1
    • There are six T8 Torque screws distributed equally along the top of the controller. These need to be unscrewed before proceeding.
    • All screws are the same length, and may have some plastic residue along the shaft.
    • A T8 55mm screwdriver is recommended, but a T7 or T9 can be used if necessary, being careful not to strip the screws.
  3. Amazon Luna Controller Teardown, Unbind the clips around the controller.: stap 3, afbeelding 1 van 3 Amazon Luna Controller Teardown, Unbind the clips around the controller.: stap 3, afbeelding 2 van 3 Amazon Luna Controller Teardown, Unbind the clips around the controller.: stap 3, afbeelding 3 van 3
    • Using a plastic spudger, a metal flat spudger or flat-head screwdriver, and a coin pick, separate the top shell from the bottom by undoing the many clips around the controller.
    • Only use a metal spudger or screwdriver for more leverage to pry off each clip, repeated mistakes as you pry apart the controller can damage the outer shell.
    • Start from the top of the controller by the USB-C port, insert the spudger into a crease between the middle of the top and the bumpers, and carefully pry apart the gap.
    • Once you hear a loud snap, it likely means a clip is unbound successfully. When this happens, do not pry more on the same spot, and use the plastic spudger or coin pick to keep that area separated as you move to a nearby gap and pry apart there with a stronger spudger or pick.
    • Continue from the top, working down the side of the controller along the outside of the handles, to the bottom by the headphone jack.
    • Repeat this process for the other side of the controller, starting from a gap near the other bumper button, work along the opposite handle and meet at the other side of the headphone jack.
    • There are a lot of clips, at least 10 large clips on the top frame and even more little clips along the edge of the bottom chassis. This process will take some time, especially if you want to retain the quality of the outer shell as best as possible.
  4. Amazon Luna Controller Teardown, Separate the top, observe the top of the motherboard.: stap 4, afbeelding 1 van 3 Amazon Luna Controller Teardown, Separate the top, observe the top of the motherboard.: stap 4, afbeelding 2 van 3 Amazon Luna Controller Teardown, Separate the top, observe the top of the motherboard.: stap 4, afbeelding 3 van 3
    • Once the clips are finally unbound, the top piece will pry off, with the face and home buttons intact.
    • The plastic D-pad piece can be pulled off of a black cylindrical post along with a rubber membrane to interface between the plastic and the microswitches on the motherboard.
    • Interestingly, the Amazon Luna has a daughter board that holds the analog sticks, B button and the hall-effect sensors for the analog triggers.
    • The second board can be removed from the main board by unscrewing one small Philips screw and pulling off the thumbstick caps to allow the sticks to fall out of the holes of the motherboard.
  5. Amazon Luna Controller Teardown, Analog sticks on the daughter board: stap 5, afbeelding 1 van 3 Amazon Luna Controller Teardown, Analog sticks on the daughter board: stap 5, afbeelding 2 van 3 Amazon Luna Controller Teardown, Analog sticks on the daughter board: stap 5, afbeelding 3 van 3
    • The side of the analog stick reads: 2124IC.
    • The analog sticks are frictionless and use green potentiometers, not sure if these are ALPS potentiometers similar to those in the Xbox series controllers.
    • The blue circle next to this stick is the trigger's hall-effect sensor which senses the magnet installed on the side of the trigger. The other sensor is mounted similarly on the opposite side of the board near the B button.
    • The middle of the daughter board has an adhesive strip covering some of the solder joints and a few test points. Perhaps some isoprophyl alcohol can soften the adhesive to remove the black strip if necessary.
  6. Amazon Luna Controller Teardown, Remove the rumble motors: stap 6, afbeelding 1 van 3 Amazon Luna Controller Teardown, Remove the rumble motors: stap 6, afbeelding 2 van 3 Amazon Luna Controller Teardown, Remove the rumble motors: stap 6, afbeelding 3 van 3
    • The motherboard is held tightly to the black plastic midframe by plastic clips, and rumble motor wires are soldered to the motherboard on both sides.
    • The blue circle is the plastic midframe piece holding the motherboard in place.
    • The yellow piece is a routing clip for the rumble motor wires.
    • The motors need to be moved to cleanly access the back of the motherboard, either by desoldering the motor wires, or softening the adhesive on the motors with isoprophyl alcohol.
    • Be careful not to damage the rumble wires on the routing clip or with the soldering iron.
    • Once the motor wires are removed, pry back the plastic pieces of the midframe on each end of the controller and pull up on the motherboard to remove it.
  7. Amazon Luna Controller Teardown, The motherboard: stap 7, afbeelding 1 van 3 Amazon Luna Controller Teardown, The motherboard: stap 7, afbeelding 2 van 3 Amazon Luna Controller Teardown, The motherboard: stap 7, afbeelding 3 van 3
    • This is the otherside of the motherboard lifted out of the midframe.
    • The chip beneath the left analog stick hole reads: winbond ''25Q128JWPQ" "2127" "6104" "4C000"
    • The chip closest to the USB-C port reads: "LP5036" "T1 188" "A805 G4"
  8. Amazon Luna Controller Teardown, Additional Notes on motherboard: stap 8, afbeelding 1 van 2 Amazon Luna Controller Teardown, Additional Notes on motherboard: stap 8, afbeelding 2 van 2
    • The USB-C port on top reads: "LUXSHARE" "22042330"
    • There is a large component near the face buttons that reads "KO" "337" "6K" "121"
  9. Amazon Luna Controller Teardown, Some Final Notes about Reassembly: stap 9, afbeelding 1 van 2 Amazon Luna Controller Teardown, Some Final Notes about Reassembly: stap 9, afbeelding 2 van 2
    • Hopefully, with the large number of clips and little number of screws that need to be reinstalled, reassembly should be simple. But some notes:
    • Within the orange circle is the magnet that pivots from the spring inside the trigger, which will approach the hall effect sensor on the corner of the daughterboard.
    • Ensure you reinstall the daughterboard behind the main board with a single Philips screw.
    • The bumpers can swing up on a pivot which can make it easier to remove the motherboard. But when trying to put the controller back together, the bumpers may get stuck. Before the main pieces are combined back together, swing the bumpers up and pull down the trigger to give the bumper room to swing down into position. Release the trigger and test.
    • The bottom piece by the handles have a long sleeve surrounded by a spring where it holds a long post from the top piece. Start realignment of the controller at the bottom, ensuring that these posts fall into the sleeves, then slowly close the controller at the bottom along the headphone jack, then
    • As you close the controller, keep testing the bumpers on the top to ensure they do not get stuck from a misaligned clip.
Damian
530 Reputatie
4 handleidingen geschreven
3Gids Commentaar
Кращеб показав відламані фіксатори корпуса =)
Зберегти їх цілістність неможливо!
Іван Панч - Antwoord
I broke a clip while removing the faceplate on mine, one of the ones on the bottom, any ideas on how to fix it or keep it held down?
cody w - Antwoord
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 130
Altijd: 1,701
