Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Afterglow Prismatic Wired Controller for Xbox One te repareren, gebruik onze reparatiehandleidingen.
  1. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: stap 1, afbeelding 1 van 2 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 Screwdriver to remove the seven Phillips head screws.
    • Separate two halves of clear casing by holding one side and lifting the other.
  2. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: stap 2, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: stap 2, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: stap 2, afbeelding 3 van 3
    • Lift motors off of controller.
    • Lift circuit board off of controller.
  3. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: stap 3, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: stap 3, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 Screwdriver to remove the three screws.
    • Remove triggers by lifting them off the circuit board.
    • Lift the circuit board off of the controller.
  4. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: stap 4, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: stap 4, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: stap 4, afbeelding 3 van 3
    • Remove the power and mute button by pulling them out. They will be loose at this point and may fall out by themselves.
Zachary Crandall
151 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-5, Forte Winter 2014 Lid van Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Leden
6 handleidingen geschreven
6 opmerkingen
how u clean it because i accident spill tea inside i cleaned it once it worked for a weak and it started to do it again how can i fix it please help me
Xavier Adams - Antwoord
You should use an earbud/”q-tip” dampened with isopropyl alcohol (otherwise known as IPA) to clean all areas affected by the spill.
infiniti25 -
a phillips #0 doesnt seem to fit into the screws.
reagen_lionel - Antwoord
How are the poitve and negative leads soldered to the board as I would like to swap wireless internals into controller and keep the lights
glohoodlum - Antwoord
I am curious about the pair of programmable wheels on the underside, do they have any markings or part numbers on them that would help in sourcing replacements? I’ve been in touch with PDP and confirmed that my controller is past their warranty period, but it is only the underside wheels that have failed and I’m trying to find replacements.
S.R. Cooper - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 152
Altijd: 26,838
