Ga door naar hoofdinhoud
« Terug naar alle verhalen
The Missing Hard Drive
stephenjoly99 -
MacBook Pro 13" Unibody Early 2011
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
25 minuten - 1 uur
Moderate
Mijn probleem
The problem was that my hard drive was not visible anymore. It wasn't booting properly so I booted to my second HD and it wasn't reading my primary HD (my SSD). Because of this I took it to the apple store to see what they though, took it to canada computers and replaced the SSD and then I saw on the apple support forums that replacing the HD cable fixes the problem.
Mijn oplossing
So I took to the internet where I found iFixIt and bought the cable from there and managed to fix the problem. The procedure was very easy and my problem was solved. The only hard part was to move my primary SSD from the optical drive caddy back to the primary bay. That took some time.
Mijn advies
The entire thing was actually very simple, like I mentioned, but I would only recommend doing this is you are 100% sure that the HD cable is the problem. Try to reformat your drives and switch bays to be sure.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable Afbeelding
$34.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 78
