Ga door naar hoofdinhoud
« Terug naar alle verhalen
iMac HDD Replacement
Joseph Abraham -
iMac Intel 20" EMC 2133 and 2210
Afbeelding van het verhaal
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
1 uur
Moderate
Mijn probleem
Original hard drive went bad, had to replace it.
Mijn oplossing
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Also, wasn't able to install the operating system from the DVD drive for some reason. I ended up cloning a drive that was plugged in via USB; I used disk utility.
Mijn advies
First, never work on an iMac when it is plugged in. There is a possibility of lethal electric shock. Second, in many instances, cloning drives with disk utility is more time effective than reinstalling from recovery disk.
4 TB 3.5" Hard Drive Afbeelding
$172.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 229
