Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
« Terug naar alle verhalen
laptop got heat during charging,stop charging,rust in the contacts in MagSafe
Den -
MacBook Pro 13" Retina Display Late 2012
MacBook Pro 13" Retina Display Late 2012 MagSafe DC-In Board Replacement
Moderate
Mijn probleem
in repair centre it coast twice more and takes two months. I don't know peoples who were satisfied such repair
Mijn oplossing
today i fixed my macbook pro. it took around 2 hours. With your guide and instruments it was very easy.but i got 2 item superfluous.First it is plastic pull tab of the microphone ribbon cable.Second it is one contact from microphone cable socket.It was very hard to pull off this cable and i pulled off this contact together with cable
Mijn advies
Thank you very much for your guides and tools ! it was very helpful.
i would like add thermal paste(and guide for this) to list of parts(in start of guide), on step 11 it was very late. now i assembled macbook without it. have i to buy it and add ?
Philips #00 screwdriver is much bigger then the same screw in step 10. This screwdriver not fit screw. i had to find smaller screwdriver
And once more thank you for your help !
MacBook Pro 13" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board Afbeelding
$29.99
Spudger Afbeelding
Spudger
$3.99
T6 Torx Screwdriver Afbeelding
T6 Torx Screwdriver
$9.99
Phillips #00 Screwdriver Afbeelding
$5.49
Tweezers Afbeelding
T5 Torx Screwdriver Afbeelding
T5 Torx Screwdriver
$5.49
P5 Pentalobe Screwdriver Retina MacBook Pro and Air Afbeelding
$5.99
TR7 Torx Security Screwdriver Afbeelding
$6.99
0 Opmerkingen
Voeg opmerking toe
