Mijn probleem
Over time, my Home button had slowly become less and less responsive. With the help of ifixit, I purchased a new button, some tools and following the guide I had the old button out, and the new one in and it works perfectly!
Mijn oplossing
The repair went quite slowly. This was my first attempt at 'electronic device repair' and I was very careful not to do any more damage, esp with the fragile parts. I was organised and using an A3 sheet of paper, drew a grid of 32 squares (there was about 32 steps in the process) This way, I made sure that all screws matched up to their corresponding step, and that none were lost. Putting the phone back toether was a lot more challenging than taking it apart. However, taking my time and following the instructions meant i had no dramas.
Mijn advies
Take your time and be prepared. If you dont have a parts tray, draw up a grid on a large piece of paper and number the squares. Put all screws/parts from each step into the corresponding square so you dont mix anything up.
Thanks Ifixit!! Very happy
0 opmerkingen
