Ga door naar hoofdinhoud
« Terug naar alle verhalen
Bulging corners
dienerd -
MacBook Core 2 Duo
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
MacBook Core 2 Duo Inverter Replacement
2 uren
Difficult
Mijn probleem
The display on my wife's old MacBook would darken to a black screen at the worst possible moment. The iFixit site helped me figure out it was the Display Inverter. I ordered the parts but didn't get to the task until three months later.
Mijn oplossing
At first I felt a bit intimidated by the nearly 50 steps for tear-down, but I dove in with confidence. An ice cube tray held the little screws I removed and kept them in order. After two hours, the MacBook was running once again. Now that I've used it for the past month, the symptoms are gone. But, two minor problems remain. (1) the back side of the hinge now has bulging corners (see images) - a reassembly error, and (2) when the angle of the display gets to about 80°, it goes to sleep - the internal switch that triggers display sleep is probably just a bit out of position. The repair was a success.
Mijn advies
I would have appreciated a "heads-up" with the addition of a comment in the directions when the hinge is removed regarding its reassembly. How do you avoid bulging corners?
Spudger Afbeelding
Spudger
$3.99
Plastic Cards Afbeelding
Plastic Cards
$2.99
MacBook Display Inverter Afbeelding
$14.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 123
