Ga door naar hoofdinhoud
« Terug naar alle verhalen
Logithech MX Master 3 thumb rubber repair
Gavriil Kamaris -
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
Mijn probleem
There is this common issue with the rubber under your thumb to rip off. I tried a couple of different kind of rubber glue without any success. Finally i used these bike tire repair patches that did the trick. A strip of rubber was completely separated form the device, you can see it in the pictures.
Mijn oplossing
After a week of use the repair seems to be successful. The patches have a low profile and the touch sense is very similar to the original one.
Mijn advies
Use some alcohol to rub the surface and clean it from any fat remains.
1 Opmerking
baton no werking
zahidul islam - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 332
