Ga door naar hoofdinhoud
« Terug naar alle verhalen
Petzl Headlight button repair
Gavriil Kamaris -
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
Mijn probleem
The rubber covering the On?Off button was destroyed after years. The PCB was revealed making the circuit vulnerable to dust and moisture and the button difficult to locate.
Mijn oplossing
I cut a transparency slide oval part to avoid the glue going all over and create a spring like behavior and also designed and 3D printed a small pin to push the button. Then i covered the assembly with mouldable glue (like sugru) to reform the rubber cover. All went well and the button is working fine
Mijn advies
Please contact me if you need any designs for the 3d print pin.
1 Opmerking
Well done! 👌Will come back to this when my Petzl button fails
Susanne - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 257
