Ga door naar hoofdinhoud
« Terug naar alle verhalen
Lookah Seahorse Pro Plus Repair
finding123 -
Afbeelding van het verhaal
Mijn probleem
1. The item did not work well and seems provide less vapors than before
2. The tip was burnt with wax
Mijn oplossing
1. Take off the core tip,the tip is connected by 510 thread,it is easy to take off.
2. Use brush to remove the burnt wax
3. If your brush can not make the burnt wax clean,please try to use a hard tool to remove it.
4. Be careful,dont destroy the coil
5. Re-install it
Mijn advies
1. Dont leave the un-burnt wax on the surface of the coil
2. Clean the core every time after use.
3. Keep the coil clean.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 213
