Ga door naar hoofdinhoud
« Terug naar alle verhalen
iMac SSD Upgrade
Carl Hill -
iMac Intel 27" EMC 2639
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
iMac Intel 27" EMC 2639 Hard Drive Replacement
2 uren
Moderate
Mijn probleem
The oem 2TB HDD was just full and unable to boot. Opted to upgrade to SSD and reinstall OS.
Mijn oplossing
Everything well very well. The kit was well worth the money as I likely would have failed without it. The new adhesive is easy to work with, the foam brace makes things easy and the SSD Temp sensor likely would have been forgotten if I hadn't just purchased this kit.
Mijn advies
Removing the screen can be tricky but just keep cutting and prying gently and slowly and it will come out. Removing and routing the cables around the HDD can be tricky but again just don't force anything and be patient.
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit Afbeelding
$115.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 271
