Ga door naar hoofdinhoud
« Terug naar alle verhalen
Successful MacBook Pro right speaker replacement using iFixit replacement
Richard Cox -
MacBook Pro 15" Retina Display Mid 2015
Afbeelding van het verhaal
MacBook Pro 15" Retina Display Mid 2015 Right Speaker Replacement
2 uren
Moderate
Mijn probleem
Rights speaker developed distortion...sounded like a perforated speaker cone...
Mijn oplossing
Straightforward but fairly lengthy mainly due to logic board removal
Mijn advies
Have right tools (pentalobe, torx screwdrivers, spudger assortment)
Use air duster throughout to clean out dust from fans and between board
layers as you go...also isopropyl alcohol on Q tip here and there.
The advice about avoiding trapped connectors when replacing logic board
was well heeded but even so careful checks needed.
Useful tools - pentalobe screwdriver, torx screwdrivers, iFixit magnetic parts mat, binocular magnifier
clip-on for spectacles (purchased years ago from Tokyo Hans store in Akihabara district, Tokyo)
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker Afbeelding
$29.99
1 Opmerking
Hi Richard, Looks like there is a flaw with these speakers. I’ve got same mid 2012 model. Some time ago the right speaker went crazy like yours did, so I turned it off and used only left speaker. And last week same happened to left speaker, so I decided finally to order R and L speakers. I am not sure yet if I do the repair myself, reading the tutorial it seems easy to ruin some connections.
chirolob - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 268
