Ga door naar hoofdinhoud
« Terug naar alle verhalen
iPhone screen replacement
kress -
iPhone 6
Afbeelding van het verhaal
iPhone 6 Screen Replacement
1 uur
Moderate
Mijn probleem
Repair cracked screen.
Mijn oplossing
Part installed perfectly according to instructions on iFixit site. Worked fine after re-assembly except ear speaker (came with screen) sounded gravelly and awful. Took apart and installed speaker from old broken screen (removal instructions also on iFixit, but took some hunting) and now works as good as new. Only flaw was the speaker.
Mijn advies
Work slowly, particularly if you don't do this regularly. Never become impatient or all is lost. It will work if you are careful.
Carefully think through each step. It's easy to miss one on re-assembly and have to take apart to fix.
Keep track of screw locations and don't mix them up.
Do not over-tighten screws. These are easily stripped. A bit of Lock-tite or similar helps with peace of mind regarding loosening screws.
iPhone 6 Screen Afbeelding
iPhone 6 Screen
$44.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 138
