Ga door naar hoofdinhoud
« Terug naar alle verhalen
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Afbeelding van het verhaal
iPhone 4S Battery Replacement
3 uren
Moderate
Mijn probleem
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
Mijn oplossing
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Mijn advies
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
iPhone 4S Battery Afbeelding
iPhone 4S Battery
$18.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 230
