Ga door naar hoofdinhoud
« Terug naar alle verhalen
Macbook Pro Battery Replacement
Kian Keong Tan -
Afbeelding van het verhaal
Mijn probleem
Battery is dead.
Mijn oplossing
Successfully replaced the battery with a new one.
Mijn advies
Don't be too quick to come to a conclusion of the battery is dead when you realized that the battery is not charging at the MacOS desktop. After I changed the battery with a new one the status remained the same. Which I then realized al the while, it was the charging curcuit of the mainboard failed.
The tell-tale sign that the charging curcuit having issue is when you noticed the Macsafe cable charging light is not turning on.
Pro Tech Toolkit Afbeelding
Pro Tech Toolkit
$79.95
1 Opmerking
Press F to pay respects.
nietsniE treblA - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 416
