Ga door naar hoofdinhoud
« Terug naar alle verhalen
First iPhone Repair
pphenow -
iPhone 5s
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
How to replace the battery in your iPhone 5s
40 minuten
Moderate
Mijn probleem
Old phone, battery was toast. Thought I'd try my first iPhone repair on what was essentially a non-functioning museum piece at this point, and thought it'd be nice to have a backup iPod.
Mijn oplossing
Went really well, minor delay when I dropped the 1.7 mm Phillips #000 screw that doesn't stick to the scredriver under the front panel assembly cable bracket.
Tested new battery, worked great. Had a little bit of trouble getting the adhesive strips on cleanly. But I put them on the old battery, which I realized after I put the old battery back into the phone.
Mijn advies
When putting the phone back together, replace the broken parts with the new, functioning parts. If you follow that advice, your phone is much more likely to work following the repair.
iPhone 5s Battery Afbeelding
iPhone 5s Battery
$29.99
3 opmerkingen
Please refrain from calling the iPhone 5s and others museum pieces they are usable phones only in need of ifixit care.
Don Marr - Antwoord Deel
Good idea using the box and a rubber band to hold the screen up! I'll have to use this next time.
Conner Stanton - Antwoord Deel
Glad to hear that you were successful with your repair!
Tommy Vu - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 343
