Ga door naar hoofdinhoud
« Terug naar alle verhalen
Changed both speakers
wisam safi -
MacBook Pro 15" Retina Display Mid 2012
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement
2 uren
Difficult
Mijn probleem
Speakers were making a lot of screeching noise at anything but very low volume
Mijn oplossing
The guide was excellent - I was super afraid I will damage something as it's the first time I open a laptop in my life (I assmbled PCs in the past but the last time was 15 years ago
Mijn advies
- ensure all cable are ABOVE the logic broad before you put it back. I had to lift it a couple of times as I kept forgetting the cables underneath it.
- be patient. If an item is not getting removed or not being inserted with ease then you're probably doing it wrong. Or something is obstructing it. Avoid the temptation due to frustration to force anything in or out at.
- arrange your screws you remove on an A3 paper and write underneath it the item it belongs.
- its ok if it takes a long time. Better safe than sorry. It took me 3h30min to finish it from start to finish.
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker Afbeelding
$29.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 332
