Ga door naar hoofdinhoud
« Terug naar alle verhalen
Painless battery replacement
quiviran -
MacBook Pro 13" Unibody Mid 2009
Afbeelding van het verhaal
MacBook Pro 13" Unibody Mid 2009 Battery Replacement
20 minuten
Easy
Mijn probleem
Started getting "Service Battery" message and the battery was only lasting about 2 hours on a full charge. Plus the computer seemed to be running warm a lot.
Mijn oplossing
Very simple. This is one of the best Mac laptops for DIY service Apple ever built. Ten screws on the back and the four most serviced components (memory, hard drive, optical drive and battery) are right there. I've been in there before to max out memory and upgrade to a 1TB hard drive (thinking about SSD options, but macOS Sierra isn't going to support this model, so we'll see) so this repair was familiar territory. The battery replacement was a piece of cake.
An added benefit, my track pad, which I thought was failing, works normally again. It seems that the old battery was bulging in several places and preventing one corner of the track pad from moving. Glad that old battery is out of here!
Mijn advies
Don't delay if your old battery isn't doing the job. There is nothing to fear if you follow this guide.
Tri-point Y1 Screwdriver Afbeelding
$5.49
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 130
