Ga door naar hoofdinhoud
« Terug naar alle verhalen
Galaxy S3 Front Glass
pep073 -
Samsung Galaxy S III
Afbeelding van het verhaal
Samsung Galaxy S III Broken Front Glass Replacement
2 uren
Difficult
Mijn probleem
Broke the front glass. I fixed it myself because I can, and because I refuse to be controlled.
Mijn oplossing
Very well. Everything works. The adhesive strip is tricky as it is the shape of the body and it sticks to fingers and there is a small amount of residue from the old adhesive still on the LCD but with the glass installed, it is covered.
Mijn advies
DO NOT rush this fix. Take your time. DO NOT heat up the guitar pick. It renders it out of shape very quickly and useless. DO NOT use a hair dryer. Hire or get a heat gun. I didn't use a thermometer because I'm a pretty good judge of heat. But don't risk it if you're not sure.
Spudger Afbeelding
Spudger
$3.99
2 opmerkingen
"Because I refuse to be controlled and because I can"
Exactly me.
Po Lu - Antwoord Deel
" I fixed it myself because I can" — like a boss! Thanks for sharing :)
Kay-Kay Clapp - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 293
