Ga door naar hoofdinhoud
« Terug naar alle verhalen
3GS Mute Button
g15389 -
iPhone 3G
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
iPhone 3G Mute Button Replacement
Difficult
Mijn probleem
I had an issue with intermittent muting of the phone when mute was on. After reading the guide and responses, I decided to give it a try.
Mijn oplossing
The repair went great! Photos were very helpful and gave me the necessary help to replace the button.
My issue was actually due to a cracked housing that holds the mute switch on the inside of the phone, probably damaged in a drop. The housing sheared in half and caused a mis-alignement of the external switch ($4.95 part) and the internal mechanism. After installing the new part, aligning the internal switch, and reassembling it works perfectly.
Mijn advies
A few pieces that help you when working:
1) A mechanics magnetic bowl. You can pick them up at home depot for around $10 and work great for holding your screws. It reduces the chance of knocking them off of the table.
2) A screw driver magnetizer. It will help greatly when trying to align the small screws.
3) Definitely get the spudger and suction cup from fixit. A must have for undoing the connections and removing the screen.
Spudger Afbeelding
Spudger
$3.99
Suction Handle Afbeelding
Suction Handle
$2.95
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 194
