Ga door naar hoofdinhoud
« Terug naar alle verhalen
Power Supply Replacement
Brandon Dusseau -
iMac Intel 27" EMC 2309 and 2374
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement
10 minuten
Easy
Mijn probleem
The power supply was buzzing.
Mijn oplossing
The repair was super easy and straightforward. It helped that I had taken apart an iMac before and so I already knew the procedure for removing the LCD.
Mijn advies
It helps to unscrew the power supply first to make it easier to reach the locking clip underneath for the power distribution cable. if you don't want to buy suction cups, the suction cup that comes with a GPS or other windshield-mounted car accessory works like a charm (but be careful not to stress the glass too much by only using the one cup).
iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply Afbeelding
$139.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 474
