Ga door naar hoofdinhoud
« Terug naar alle verhalen
Fixed it!
autococker13 -
Xbox 360
Xbox 360 Red Ring of Death Fix Kit
45 minuten - 1 uur
Difficult
Mijn probleem
RROD
Mijn oplossing
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
Mijn advies
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in the oven at 200 degrees for 10 min to uniformly heat the board before I started; it's not too hot to hurt anything. From there I heated each of the chips with the heat gun on high for about 4 minutes total and then let the motherboard sit for about an hour.
Heat Gun Afbeelding
Heat Gun
$29.99
T3 Torx Screwdriver Afbeelding
T3 Torx Screwdriver
$5.99
iFixit Opening Tool Afbeelding
iFixit Opening Tool
Arctic Silver ArctiClean Afbeelding
$9.99
Xbox 360 Red Ring of Death Fix Kit Afbeelding
$29.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 101
