Ga door naar hoofdinhoud
« Terug naar alle verhalen
iPhone 4S Rebuild
cpwittenberg -
iPhone 4S
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
iPhone 4S Headphone Jack Cable Replacement
2 uren
Difficult
Mijn probleem
My old iPhone 4S needed a new dock connector--it always thought it was docked, and was discharging itself and getting hot. When I replaced the dock connector, I broke the home switch cable. Then while replacing the home switch cable, I broke the secondary mic off the headphone jack.
Mijn oplossing
Due to all my mistakes, I essentially had to do a full disassembly, replacing the headphone jack/secondary mic/volume button/hold button flex AND the home button switch. I have worked inside the iPhone 4S a few times, but never had to disassemble so much. The repair succeeded perfectly, thanks to experience. But it felt like Mission Impossible.
Mijn advies
Don't try replacing the iPhone 4S headphone jack assembly unless you have some experience and a good magnifier. Also, always read the comments for tips about difficult-to-see items, such as the secondary mic which is tethered to the headphone jack.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 382
