Ga door naar hoofdinhoud
« Terug naar alle verhalen
Not Enough Space
Lojeck -
MacBook Core Duo
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
MacBook Core Duo Hard Drive Replacement
5 - 30 minuten
Easy
Mijn probleem
I had a hard drive with 160 GB of space. I do a lot of graphic art and multimedia work and my disk space was full and it began a kernel panic that would cut my machine off in the middle of projects. Grrrr!
Mijn oplossing
The repair was straight forward and simple :)
Mijn advies
Make sure to download a hard drive cloning program like SuperDuper!
Also, if you disconnect your battery connector from your logic board make sure to plug it back in. I forgot and powered up! Luckily the connector went back into place when I closed it back up...whew!!
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 119
