Repareer je spullen
Recht op reparatie
Winkel
MacBook Unibody (A1342) Lower Case Screws
  • MacBook Unibody (A1342) Lower Case Screws
US$ 14,99
US$ 14,99
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
Productdetails
Beschrijving
Beschrijving
This set includes all of the 8 lower case screws.
Compatibiliteit
Compatibiliteit
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Specificaties
Specificaties
Part #:
605-2896
Model #:
A1342
Compatibiliteit
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
Reparatieverhalen
Gebruikersavatar
gveldman's Story Photo #462277
Mijn probleem
A few weeks ago the rubber coating released it self, caused by the heat, from the lowercase of our Macbook, end 2009 version. Because the Apple replacement program was not applied on this Macbook, I decided to repair it my self. The Macbook is in perfect state, including 4GB memory and running Yosem . . .
Gebruikersavatar
Mijn probleem
The missing screw was just the right one and I screwed it in seconds, thank you IFIXIT
Mijn oplossing
very well
Mijn advies
buy it - it works
Gebruikersavatar
Mijn probleem
I wasn't able to use my Mac because of the fan. As soon as I would turn it on, it would start over heating and made it go really slow due to the heat. Finally I decided to order the parts to fix it.
Mijn oplossing
The repair went very smoothly! Of course I already have a lot or technical experience since I'm a ce . . .
Gebruikersavatar
Mijn probleem
The 5400RPM HDD had seen better days. It was slow, slow, slow. Also installed a total of 4GB of Ram. It now performs like a much newer system. I think we have a couple more years of productive use from it.
Mijn oplossing
The repair went very smooth. Since I had the Pro Tech Toolkit, all the steps where easy as . . .
Geef meer weer
