Ga door naar hoofdinhoud
uAttend bn6000 Keyboard Replacement
Wat je nodig hebt
  1. uAttend bn6000 Keyboard Replacement, Disassembly: stap 1, afbeelding 1 van 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    Vraag FixBot
    Voeg opmerking toe
  2. uAttend bn6000 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
    Vraag FixBot
    Voeg opmerking toe
  3. uAttend bn6000 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 uAttend bn6000 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Remove the five 7mm PH #1 screws from the back of the keypad, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    Vraag FixBot
    Voeg opmerking toe
  4. uAttend bn6000 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the bundled cable connector from the keyboard by pulling the cable away from the connector in the same direction as the individual wires are running.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Will Mastel
122 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 599
