Ga door naar hoofdinhoud
uAttend bn6000 Fingerprint Replacement
Wat je nodig hebt
    1. uAttend bn6000 Fingerprint Replacement, Disassembly: stap 1, afbeelding 1 van 1
      • Make sure to unplug the device before starting.
      • Flip the device over.
      • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
      Vraag FixBot
      Voeg opmerking toe
    2. uAttend bn6000 Fingerprint Replacement: stap 2, afbeelding 1 van 1
      • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
      Vraag FixBot
      Voeg opmerking toe
    1. uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 1 van 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 2 van 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 3 van 3
      • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
      • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
      Vraag FixBot
      Voeg opmerking toe
    2. uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 1 van 3 uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 2 van 3 uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 3 van 3
      • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble , follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
abdullah sumait
437 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 946
