Ga door naar hoofdinhoud
Dell OptiPlex GX260 Power Supply Replacement
Stap 2
Dell OptiPlex GX260 Power Supply Replacement: stap 0, afbeelding 1 van 1
  • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
  • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
  • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
Vertaling hier toevoegen
