Ga door naar hoofdinhoud
Dell OptiPlex GX260 Power Supply Replacement
Wat je nodig hebt
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 Power Supply Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: stap 2, afbeelding 1 van 1
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: stap 3, afbeelding 1 van 1
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: stap 4, afbeelding 1 van 1
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.457 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
Één opmerking
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 12,767
