Ga door naar hoofdinhoud
iPhone 6 Power Button Cable Assembly Replacement
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 2 handleidingen die deze stap bevatten.
Stap 2
iPhone 6 Power Button Cable Assembly Replacement: stap 0, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 0, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 0, afbeelding 3 van 3
  • Gently pull the battery adhesive tab away from the battery, toward the bottom of the iPhone.
  • Try not to pull against the battery or the lower components, or you may rip the adhesive strip.
  • Continue pulling, allowing the strip to slowly slip out from between the battery and the rear case. When you feel increased resistance from the strip, stop pulling and continue with the next step.
  • If the battery adhesive tabs break off at any point during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then proceed to Step 44.
Vertaling hier toevoegen
