Ga door naar hoofdinhoud
Garmin Avionics Wiring Termination
Stap 9
Garmin Avionics Wiring Termination, Wire strip length: stap 0, afbeelding 1 van 3 Garmin Avionics Wiring Termination, Wire strip length: stap 0, afbeelding 2 van 3 Garmin Avionics Wiring Termination, Wire strip length: stap 0, afbeelding 3 van 3
Wire strip length
  • The wire strip length should by just barely longer than the barrel (where the wire goes) of the crimped contact
  • First picture shows a correct termination
  • Second picture shows to long of strip on wire
  • To make sure the wire is stripped long enough the conductor strands should be visible in the witness hole circled in the third picture
Vertaling hier toevoegen
