Inleiding
This is a guide on the technique on how to terminate wires for a Garmin Avionics Install.
This is not approved material and all work done on aircraft should be done by certificated individuals per the appropriate manual.
This guide covers the use of a twisted pair wire but the technique is applicable to any shielded wire.
DMC crimpers with appropriate turret
Wire strippers
Flush cuts
Razor
Fine tip sharpie, or label printer for wires
Heat gun
Wire
Shield braid
Heat shrink (2 pieces), at least one piece white
Environmental splice
Pins
Interior wires- where the signal is passed through
Outer layer of insulation
Shielding- a braid inside the wire over the interior wires. This protects the signal from interference or interfering with other signals. The shielding is terminated to a ground
Remove shielding to expose wires
Option 1: unbraid shield and the cut away from wire
Option 2: carefully cut shield away without nicking the interior wires
Cut a 0.25" long section from outer layer of the wire about 2.5" from the end of the wire.
This accomplished with a razor. A new razor will cut more easily through the insulation but can also cut through the shielding. A dull razor is harder to cut with but also more forgiving to mistakes.
If the shielding is cut through and the interior wires nicked there is a high potential for a short to ground and that section of wire must be cut off and the wire must be restarted.
Insert the environmental splice over the cut shielding block and insert the shield braid into it. The solder ring must go over both the exposed shield and the braid.
Insert a piece of heat shrink over the end of the wire where the shield and outer insulation is cut. This will protect the end of the wire
Heat the splice and heat-shrink with a heat gun. Ensure the solder flows in the splice soldering the braid to the shield.
Strip wires appropriate length - detailed in next step
Crimp terminals to wire
The wire strip length should by just barely longer than the barrel (where the wire goes) of the crimped contact
First picture shows a correct termination
Second picture shows to long of strip on wire
To make sure the wire is stripped long enough the conductor strands should be visible in the witness hole circled in the third picture
Add heat-shrink with wire number added to it to identify wire after install
Push pins into connector, the should lock into place and need a special tool for removal
Crimp ring terminal to shield braid
Install ring terminal to designated grounding location. Often the connector back-shell.
This step is done last after all wires for a connector are installed and back-shell is assembled on connector. Sometimes a separate ground lug needs to be installed onto the back-shell.
Één andere persoon heeft deze handleiding voltooid.
