Ga door naar hoofdinhoud
ionvac SmartClean V2 Shell (Top & Bottom) Replacement
Wat je nodig hebt
    1. ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): stap 1, afbeelding 1 van 2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): stap 1, afbeelding 2 van 2
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      Vraag FixBot
      Voeg opmerking toe
    2. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 2, afbeelding 1 van 3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 2, afbeelding 2 van 3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 2, afbeelding 3 van 3
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      Vraag FixBot
      Voeg opmerking toe
    3. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 3, afbeelding 1 van 1
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      Vraag FixBot
      Voeg opmerking toe
    4. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 4, afbeelding 1 van 2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: stap 4, afbeelding 2 van 2
      • Lift the top shell off carefully.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ruth Mekonnen
794 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 390
