Inleiding
If you notice that your ionvac SmartClean V2 has a shorter runtime or decreased performance, it may be time to replace the batteries. This guide demonstrates how to remove the lithium-ion battery unit from the bottom of the robot vacuum.
This is a quick and simple repair, but handle all parts gently during removal and reinstallation. Before you begin, power off your ionvac SmartClean V2 and disconnect it from the charging dock.
Caution: If you notice the battery is puffy or smells strange, it may be swollen. Be careful when handling a swollen battery as it can be a fire risk. For more information on swollen batteries and what to do with them, take a look at the What to Do With a Swollen Battery guide.
Wat je nodig hebt
Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
Één andere persoon heeft deze handleiding voltooid.
2Gids Commentaar
need instructions for installation of battery in TZUMI ion vac smart clean robo vac V4
need instructions for installation of battery in TZUMI ionvac smart clean robovac V4
